Matching Amps and Subs
mrnbooc
I am trying to figure out is there an easy way to match amps and subs. I am concerned with buying an amp that will be too powerful for a set of subs or not powerful enough.
I do understand looking at the ohm ratings by looking at what the amps and subs are rated at concerning ohms. So matching an amp in 2 ohm mode works better with subs rated for 2 ohms.
My question is the RMS ratings. If an amp is rated at 100 watts by 4 channels, that will put 25 watts per channel output from the amp.
So do I judge what subs to get by the rms rating of the subs or the peak power handling?
So should I look for subs rated at 25 watts RMS or 25 watts peak power handling?
Also any suggestions will gladly be taken.
100wrms X 4 means 100 watts per channel
and FORGET peak ratings always use rms as your guide
also, just because a sub might say 2 ohms on the box does not mean that you need a 2 ohm stable amp. It means that 2 ohms is the load per coil so if they are dual coil subs with 2 ohm coils, if you had one sub, you need a amp that makes power at either 1 ohm or 4 ohms
Thanks for the input.
I think I see what confused me. When looking at amps the power rating isn't split per channel it is the power per channel( 100watts x 4=100watts per channel for a total of 400 watts).
I looked at a HU and the power rating is 200 watts and it is split per channel and that is what was in my head when looking at amps.
Thanks again.
mrnbooc
mrnbooc
Fayetteville,NC
mrnbooc
