Matching amp RMS and Sub RMS
  • 4
Thank you so much, Deez!
I am so dumb, because I just started getting into DIY car stereo.
Can you please let me know how to set the gains correctly in this case?
41266
Is gain "Input Sens?" So, you turn it down counter clockwise when you hear sound of stress?
Please let me know if I can run a 150 RMS sub with 500 RMS amp.
JL HD 900/5, 100 X 4 Plus 500X 1
Dynaudio MW 172, 8 inch, Nominal long term IEC 150 W Transient (10 ms) 1000 W
Absolutely. Tune properly and you should be just fine. Head room is always nice to have usually. The amp generally runs cooler and does not work as hard and should last a bit longer as well.
You have way more chance of killing speakers with not having enough power to them.... most guys crank it trying to get loud and the clipped signal ( distortion ) has high death rates. You can have lots of power and not use it all. Like mentioned above.... set the amp to lower power gives much better head room ( cleaner power and better sound )
Im sure you could find a great deal on here as well for your mids and highs. Just another great speaker to be considered. Audio Frog may be...
looks like it will work just fine. this amp would work just as well if you want to save a little money. I run one of these and a 2k as well. Both...
For that sub.. A single sub.. You will need an amplifier to be stable @ 2 ohms, of approx 1500-2k rms or an amplifier @1 ohm stable at approx...
875
Check out the Down4Sound JP95 5-channel amp. It may be the 5-channel amp you are looking for.
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
Johnnie
Johnnie
Johnnie
slater
    May 2, 2024
slater
    May 2, 2024
