MAJOR PROBLEM...help me out
well it did make a huge difference but the box still seems as tho its tuned WAY low. i was looking for anywhere from 33--37hertz. any of those would be fine...6" aero port that is 11" from end to end...right?
here are a few pics of my box in question
[/img]
[/img]
[/img]
port is directly in the middle of that board firing into the car...could anything about the port mess up tunning? also
please tell me what i should set my filters to again on my amp for four 10's and i listen to rap...
lol thanks ya its painted with textured spray paint then splatter painted. but anyways the amps are wired up 100% as you told me to do. it made a difference but its still not as loud or hard hitting (best way to describe it) like i could set off a car alarm from a good distance. now i think i would need to be exactly next to another car to set it off...
ALSO the box is 4.595 cubes. 6" aero port that is 11" long from flare to flare...whats my tuning? sight at 36hertz right?
second could my problem be that my box is too big for these subs?
i was 100% happy with them when i first had them. guess you didnt read everything. all i ever wanted to do was give them a little more power and change the box design so i have more room to work with in my trunk. so all ive done is get a battery, another nine,1 and new box.
so what is your problem now?
well i switched boxes added the other amp and battery even got bigget wire all around and the **** subs hit harder before with only a single nine.1. also there SQ has went down the drain...
michaellane
michaellane
tx
michaellane
