MAJOR PROBLEM...help me out
michaellane
first off i drive a 2002 accord. 0 gauge welding cable and a big c&d battery in the back. //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying:
i have four of these subs pb10-4
http://www.credencespeakers.com/Clearance_Corner.htm
my box is 25" deep x 27" wide x 14.75" tall
i have one 6" aero port that is flared on both ends. the pipe in between the ends is 6" long. the port fires into the cabin/car and subs are m0unted on top of the box. the port is smack in the middle of the back board (27" X 14.75")
i also have a nine.4 that is working great!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well my subs are single 4ohm. i wired them up to have a final load of 4ohms (checked with DMM).
next i ran the positive speaker wire to my FIRST/MASTER nine.1....then the negative speaker wire to my SECOND/SLAVE nine.1.
so each amp is seeing 2ohms. o out put should be roughly 900--1000 per amp. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
now when i play young jeezy welcome back it sound like complete crap. almost as if they were being under powered. if i turn it up like i use to it sounds crappy and the subs almost bottom out AND is NOWHERE NEAR AS LOUD AS IT WAS BEFORE I ADDED THE SECOND AMP. why is this? what have i done wrong???? when i ran them off a single nine.1 wired to 1ohm they slammed, now its crap...//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif:crying:
both amps are set right as far as slave and master.
am i right that the slave amp will have all the same settings gain, lpf, ssf as the master without changing anything on the slave amp correct?
how are they wired for master/slave? I've only done AQ/Sundown amps, so not sure if yours are the same.
NEG speaker wire goes to POS on the Slave amp. NEG's from both amps are connected. RCA's into the master and a single RCA connects master/slave...
yes, master controls everything, slave settings make no diff...
any ideas what could be going on??? i just spent all day moving all this crap around and putting everything in...this sucks to finally get done at 12:pm go for a ride and hear this crap
michaellane
michaellane
tx
michaellane
