Yea because that stock engine bay is pumping the horsepower. lol.
Automatics are for high horsepower, 1/4 mile dragsters. You have an autocross / Rally machine. Manual or go home.
Edit to add: Lol @ reference of PSI to horsepower. Boost pressure is NOT the end all of power production. CFM is. Running 25psi on a tiny turbo will make much less power than 12psi on a huge turbo.
yes because engine bays put out power.//content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
go manual or go home. you obviously know nothing about subaru's
yea, i know the diff between turbos.
thanks for informing me on nothing.
edit: and where did i reference psi to horsepower?
learn to read and stop making shit up.
i said the stock 4 speed manual can hold up better to higher psi's than the stock 5 speed manual can.
bunch of ****ing retards on this forum.
those are 8k eagle eye hids. it doesnt have projectors but im getting them retrofitted.
it is because i took the pic with the sun right on the headlights.
whoever told you that lied to you. a built automatic is stronger than a build maual. if you were right everyone that has a WRX would have an auto. crank up that boost to 18psi and watch those spider gears and ****** case get destroyed.
you obviously dont know how to read, and know nothing about subaru;s either.
where did i mention built ******'s? once again dont know how to read and making shit up.
the stock 4 speed automatic out lives the stock 5 speed manual, cause the gears are built like glass.
i am putting a vf39 with upgrade injectors, fuel pump, and possibly a front mount, and it will be running 18 psi. there are many people with 20+ psi with big 16 and 18g turbos on stock 4 speeds and they are still running strong.
no gears are gonna slip you dumb ****.
edit: where did i mention built ******'s? once again dont know how to read and making shit up.
lol like how this G be doggin mannys, nagga dont no shit, nice car tho bro, I guess it can hold up to your .05lbs of boost better.
stock is running 14.5 psi from a td04 turbo.
i would have gotten a 5 speed manual, if i knew i would have the money to put ppg gears in it, which will cost roughly 5k, which i dont have.
so learn to spell before you "dog" on someone, and know what your talking about before you "dog" on someone else shit.
How much and how much mileage?
48k miles, only tracked once.
14 flat with the avic d2 with xm, LE mudflaps, hids. hella supertones, and some other small shit.
