M7 set screw
what I found is "M" is the diameter or width.
M7 is 7mm wide thread M7 10mm is 10mm long.
This is new to me.
https://www.aliexpress.com/item/200pcs-Stainless-Steel-Allen-Head-Socket-Hex-Grub-Screw-Multi-size-Socket-Head-Set-M1-M2/32919637970.html
that kit has 7mm but only 4mm long
https://www.aliexpress.com/item/240pcs-Black-Allen-Head-Socket-Hex-Grub-Screw-Set-Assortment-Kit-M1-2-3-4-5/32919629999.html
that 1 has 7mm but the  x 6 x 3mm I have no clue what that means.
I'm trying to find the same thing but for the speaker wires. I think they are 4mm
you might be on to something my friend!!! im not sure why 3 dimensions are listed, but heres one that seems to be a bit longer
it seems to be described as this M7 x 7 x 4mm  M7 for the screw description, then 7 (millimeters i assume in width) then 4 mm length
but look at the package details of that thing. It describes the M10 in a very similar fashion as 7x6...
Parameters:Material: stainless steelList:20pcs allen head screw: M1 x 2 x 2mm20pcs allen head screw: M2 x 3 x 2mm20pcs allen head screw: M3 x 5 x 2mm20pcs allen head screw: M4 x 3 x 3mm20pcs allen head screw: M5 x 5 x 3mm20pcs allen head screw: M6 x 4 x 4mm20pcs allen head screw: M7 x 7 x 4mm20pcs allen head screw: M8 x 5 x 5mm20pcs allen head screw: M9 x 10 x 5mm20pcs allen head screw: M10 x 7 x 6mm
https://www.aliexpress.com/item/200pcs-Stainless-Steel-Allen-Head-Socket-Hex-Grub-Screw-Multi-size-Socket-Head-Set-M1-M2/32919637970.html?spm=2114.10010108.1000013.1.72222f31sme7gx&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm_id=1007.13339.90158.0&scm-url=1007.13339.90158.0&pvid=46647e59-26db-4f1c-88dc-213a32870594
Cartel said:
It sucks doesn't it OP?
just finding a set screw is a real chore.
Try finding a service manual or schematic. Even voltage check points or talk to a tech about something
Not gonna happen..
No wonder this industry is dead.
The only place is....wait for it: China!
Made in the USA!!
YA sure it is uh huh. wheres those parts then?
These companies dont even answer phones or emails.
https://www.google.ca/search?q=gold+set+screw+grub+aliexpress&hl=en&prmd=ivns&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiLzL2G5ObfAhWO11QKHWzkAoEQ_AUIBQ
hey, toolmaker has them. hit them up on fb. they didnt charge me for one of them, but im going to give them some cash somehow. no free lunch, ya know?
youdoofus
Skibidi
youdoofus
planet earth
youdoofus
NorthFramingham
    Jun 30, 2026
