lowes/home depot electrical power cable for amp?
  • 4
ExplicitUrSelf
as the title what are your thoughts on doing this? what are the pros and cons on using this type of power cable to run from my engine bay battery to my rear distributor block. i curruntly have kicker flex power and 4 awg from battery to dist block and 4 awg continued to two amps.my amps sundown saz 1000.1 d and a cadance xenith series 125.2. in currently runnig my sundown at two ohm and i what to be prepared to run the amp at 1 ohm in the future. feed back would be great thanks
I doubt anyone is going to agree with me but I've used the thick industrial strand (19 strand count) 0 awg and never had a problem. I have no problem bending it but i've never needed to tie my wire into a knot like people like to show. The reason I first tried it is because I got almost 300 feet of it for free. I still use it, have it in my MR2 right now. Use it you will be fine.
Done b4, work fine.............
Here is the plan. My car is on a bit of an incline, the nose is sitting about half a foot higher than the rear. The little bit of windshield...
745
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
I haven't had a proper home theater or home audio system in quite a few years but here's what I remember. I like both systems to perform the same...
14
Hey guys didn't realize this thread got revived. Decided to bite the bullet and buy a used Yamaha receiver. 6 channels 100 wats per channel with...
13
ExplicitUrSelf
ExplicitUrSelf
Riverside county
masterbarber
