Low voltage
Ive got a pioneer GM d9601 running at 1 ohm on a 2010 fi q with extra spider and cooling option and also a clarion apx 4240 bridged running my coaxial alpine type R 6.5 up front.
I have the big 3 done (I think I did it right)and a stinger spv70 battery relocated to the trunk with 0 gauge wire ran to the battery.
The car is a 1993 camaro z28 and when I drive my stock car battery meter stays at about half which is around 11-12 volts I think. That's awfully low for a 1500 watt RMS system with a huge battery and big 3 and some people are putting 2k on a stock electrical.
I was hoping maybe you guys could help because I'm looking to upgrade my sub amp to a skar RP1500.1 and my mids and highs to a Rockville amp 4 channel at 100 watts per channel. That's about 2k watts and idk if I can upgrade considering I'm already at low voltage with my current setup.
Maybe I did something wrong but I don't think I did.
If you need to know anymore info or need pics just ask and please help!!
Get an aftermarket volt meter and hook it directly to the amps or the batteries, your dash voltmeter is never to accurate. Mine basically bounces from side to side even if I'm dropping less then a volt.
collinhawks
collinhawks
Spring Hill, FL
atoz2
