Low Voltage
dirtyunclerandy
At full tilt voltage going into the 11's. Running DDm1c on stock battery and alternator. Upgraded the grounds for the big two, but can't run the upgraded power wire to make it the big three. So what are the best options to keep my voltage up?
Need to put the car up on a lift. Not enough room to do it topside.
---------- Post added at 07:08 PM ---------- Previous post was at 07:07 PM ----------
Already did.
wire up then, makes ur amp more efficent
Replace the stock batt with the largest AGM you can fit under the hood and get that 3rd wire done, that should put you to at least mid 12's.
[quote name='dirtyunclerandy']Any brand in particular you recommend?[/QUOTE]
@snoopdan is selling a minty deka on the cheap that, if you can fit it, would be a great addition. He's asking $80 + ship iirc
I did yeah. The OEM Harness was frustrating because the pinouts for the aftermarkets had the wrong layout. I have it correct. I'm measuring low...
The amp is only about a month and a half old but did run it couple too many times clipping and even saw the protect light flash a couple times I...
991
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
If your last problem was the same as this one, you know exactly where to start. Does it change based on vehicle speed or engine speed? Does the...
114
dirtyunclerandy
dirtyunclerandy
Austin, TX
dirtyunclerandy
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
