Low depth 6.5s
  • 5
TrnItAround
im looking to replace the stock 6.5"s that ae in my kickpanels.
Im looking for a set of good speakers but i am also on a budget and dont want to spend too much.
my only problem is that there is not much mounting depth to work with.
So ill need to find some speakers that have a very shallow mounting depth. If any boyd has some suggestions please let me know.
im just looking for the lowest depth possible. and yes im coaxial because i dont want to spend over 150 bucks.
Sigh...I don't see your reasoning. But the Infinity Reference shallow versions would fit the bill...Most low end coaxials like that will be plenty shallow anyway, so I would not worry about it too much. I still don't see the big deal in measuring to be sure something will fit.
or just go to crutchfield choose the type of car u got and see what speakers would fit and check the mounting depth of those speakers be sure to check various brands mounting depth and find the deepest one that will fit and this will give u a clue on how much space u got without measuring . tho if u measure odds are 1/4 or more of space may " magically" appear //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I second this...
the infinity tweets are a little harsh but those should get the job done.
I second this...
Mounted off axis in a door will pretty much completely get rid of any sibilance or harshness. I think they'd be pretty good...
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
129
433
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
611
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
TrnItAround
TrnItAround
Riverside, Ca
nosaj070
audiobaun
    May 19, 2024
    May 19, 2024
