Loudest system possible W/o HO alt??
i want to get the loudest and best sounding setup i can get w/o having to upgrade my electrical system. I dont want L7's or type r's. I was told on there that i should go with a a kicker zx1500.1 and 2 12" RE Audio SE"s. but there peak RMS is only 600 watts. i think ill stick with the amp but im not so sure about the subs. and i dont want any FI stuff they have to many spider problems. thanx by the way i cant fit 15" subs i only want suggestions on 2 12" subwoofers.
First off, who told you the Fi's have "spider problems"? Secondly...good luck running a 1500.1 off a stock electrical system.
he'll be fine with that amp on a stock electrical. I have the exact same amp on my hondas alt which is about 80 amps. Amp is very efficient. Run it at 2 ohms as well. All you need is an extra battery in the trunk and you should have 0 problems. I also have a mtx 2300xw which is 150x2 as well as my kicker zx1500.1 on my stock alt, no dimming.
MJ23dynasty
MJ23dynasty
Harrisburg(Star City), Pistolvania
10W3dodge96
