Loud Daily Driver Box
  • 6
brokeitagain
auto body tech:)
334
MO
im going to do 2 L7 12'' in my blazer soon. Im gonna try 6.5 cubes, 2- 3''W x 13.25''H x 14.5''D slot ports. I am hoping this gets me somewhere, i gave up on the Memphis M3's They just arent loud enough. I am considering using 2 Kicker ZX 1500.1's or 2 ZX 1000.1's to power them, Maybe 1 ZX 2500.1
My box is going to be 36''W x 15''H x 25.75''D
What i want to know is: Will this be a good loud setup for my blazer, Kicker reccomends 3.25 cuft after displacement per sub With one 13.5 x 3 x 14.5 D port for a single sub, i am planning on doubling everything to run two subs. Will this be correct?
Does any one have a better suggestion?
I am using a single L7 12'' that the car audio shop owner let me use for a few days to see if i like it. For now i have a Memphis PR 1.1000 powering them but soon i will pick the amps i will run
i would need dual 2 ohm subs, i dont think the zx 2500 does 1 ohm, Dual 4 will only get me 1 or 4 ohm
it'll do 1 ohm if you have a decent electrical system. i run my kx at 1.4 with a 240a alt, 2 yellow tops, and 1/0 big 3 and i dont get any dimming if i'm driving. drops to about 12.5v if i'm at idle and full tilt.
dont try that without at least an upgraded alternator and big 3 though.
although to be honest, it should do enough power at 2 ohms to run those l7's hard. not really any sense dropping it to 1 and pulling the extra current.
the box is the issue i have atm. i need to be sure what i have planned is going to be right
BTW: I just talked to the audio shop owner im supposed to be getting the '08 models
How big and how much port then. I dont wanna build 500 boxes and not be happy. I dont Just want SPL i want to be able to use it to listen to music too, But i want it to be loud
2.5ish cubes per sub, imo. Once you start going so big you lose peaks and mechanical power handling drops.
So i need 5 cubes after sub and port displacement. I dont know the displacement on the subs yet, Im getting the '08 L7's and kicker does not have that up yet on their site, I would like to know how much port i need. 50 sqin? How long?
If i can figure out what i need for a port i will do a single center slot port. it will help brace the top and bottom of the box and i wont have to add so much bracing. I plan on resining the inside of the box, just because i know how to now,
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
981
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
brokeitagain
auto body tech:)
brokeitagain
MO
brokeitagain
    May 20, 2024
    May 20, 2024
