Lost need help bad
yes you will need an adapter, and you could get it at walmart or autozone or the net. you can get them from scosch. it will say on the back of the package on the applications it would be used for. just look on the front for buick applications and then on the back to make sure your car's year and model is on there. if you cant find one, just search -96 buick lasabre stereo wiring harness- in google and you shall get your answer
Ok I have received both parts that I needed but well, here we go lost yet once again.
I matched all the wires other than these from the adapter:
1. Black w/white stripe: Aux shield ground
2. Orange: Illumination dimmer
3. Blue w/white stripe: Amp Turn on
I can account for the Blue w/white stripe, I have no amp at all. As far as the blac w/white & Orange thye go to no wires on the adapter. Would this all be correct ?
Thanks guys
Ahh well I would have said if it did or not IF in fact I even hooked it up. Which I did not
At any rate, I believe I am correct lol
Zombie
Zombie
Ca
jmanpc
michigan born
    May 14, 2026
michigan born
    May 14, 2026
