Lost a channel on my amp, somewhat
  • 1
Force-fed
Front comps are running off an old zed built usa 2100, on my way home today the speakers kind of went in and out and sounded way off, then fine, then quiet, then midbass was fine but tweeters were quiet, and when i turned the balance to the right it would start to move the sound to the right but when the balance got all the way right, the sound would come out of the left side but really muffled? I was extremely confused, figured a wire short, checked out the wires, looked fine. I put the dmm on the amps left channel with music on, then to the right... The left was showing voltage moving with the music, the right was dead but not completely. It showed voltage with the music but way lower than the left channel, any ideas what to look for? I wired both comps to left channel and adjusted the gain for the new ohm load and the speakers sound fine.
Does anyone repair old usa amps?
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Ok. we have a way to move forward so let's get to the shopping list. I wanted to do this yesterday but I had my ass chained to an o-scope all day...
21
269
Force-fed
Force-fed
Upstate, NY
Force-fed
    May 24, 2024
