Looking for a upgrade!
Anything is better than kickers. DO you want to go SPL or SQ? How much $$$ are you working with. What gauge wire are you running now? Look into Fi, DC, DD, Audioque/Soundqubed. Stay away from Best Buy brands...
I'm looking to do a complete overhaul with brand new box and new woofers and amp(s) and like to keep it under $1200 total with everything
oh and as loud as possible. ive been looking through dc audio and dd's but just cant decide on a sub amp combo
which 10's? cause if i can power them with my amp i can pretty much go with alot of things what would you recommend then?
as long as its louder, plus my main thing right now is going at low at possible any 10's that will shock me with the low notes
yea the dc subs will and they like small boxes ,if you decide to go that route ,hit me up for prices shipped
You're in a bit of a predicament. If you run that amp you need dual 2 subs. If you decide to add power later you're going to need $400-$500 in a larger alternator but also want a 1ohm amp. You could run .5 if you get a 270-300 amp alt and not worry about adding a battery to the back since its already tight. I would do a set of DD 3510s at dual 2 then after you can make the power run a DD M3 at .5 on them. See how far you are from pulse car audio. Those guys know what they are doing.
NickV214
NickV214
Baltimore, Md
Silverado SS
