Sold looking for a 400- 800 watt 2 channel amp
Hey Rctecnic what is the watt rating on your crunch p2250? I am very interested in it. As for you chawtain I have a fusion powerplant 500.2channel amp that would push your wife's kickers great. I have had it hooked up to 4 kicker comp 10's and bumped good. I mean if the rear view falling off the rook helps then holla at me Its cheap..
here's that info you wanted.
Crunch p2250.
Amplifier Type: 2-channel
RMS Power: 250W x 2
2 x 250 Watts @ 4 Ohms
2 x 500W @ 2 Ohms
1 x 1000W @ 4 Ohms
Bridged RMS Power: 1000W x 1 (Maximum)
THD at Rated RMS Power: 0.05 %
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 20-30,000 Hz
Channel Separation: >70 dB
Signal to Noise Ratio: >90 dB
Fuse Rating: 2 x 25 amps
chawntain
chawntain
columbus afb, ms
civilicious
    Jun 20, 2026
    Jun 20, 2026
