Looking at JL Audio 10 inch??
icwe2
10
LA
Im looking for two ten inch subs that will run good off of a 800 watt pioneer amp.
I was thinking of getting JL Audio 10W1v2 4 ohm. Anyone hear any good or bad things about these subs or have any good suggestions for 10 inch subs that are under 100 a piece?
JL Audio 10W1v2-4
Technical Specification
* Sensitivity: 84.53 dB
* RMS Power Range : 150 Watts
* Peak Power Handling: 300 Watts
* Impedance: 4 Ohm
* Diameter: 10 Inch
Features
* 10" W1 version 2 4-ohm subwoofer
* Continuous Power Handling (Pt): 150 Watts RMS
* Nominal Impedance (Znom): Single 4 ohm
* One-Way, Linear Excursion (Xmax)*: 0.375 inches / 9.5 mm
* Nominal Diameter: 10.0 inches / 250 mm
* Overall Diameter: 10.5 inches / 267 mm
* Mounting Depth: 4.34 inches / 110 mm
* Net Weight: 7.81 lbs. / 3.54 Kg
* Driver Displacement: 0.025 cu. ft. net / 0.71 liters
* Rec. Sealed Enclosure: 0.625 cu. ft. net / 17.7 liters
* Rec. Ported Enclosure: 1.00 cu. ft. net / 28.3 liters, tune to 31 Hz
heres the amp i have
Pioneer GM-D7400M
* Class D amplifier minimizes power waste and heat generation.
* 800 Watts Peak Music Power
* Continuous Power @ 4 ohm: 250W x 1
* Continuous Power @ 2 ohm: 400W x 1
* CEA2006 Specifications:
o 400 Watts x 1, at 2 ohms
o 200 Watts x 1, at 2 ohms
o 80 dBA Signal-to-Noise Ratio (Reference: 1 Watt Output)
* Extra-compact Class D amp circuitry for extra-versatile installation.
* Variable Bass Boost precisely controls audio balance and impact.
* 2 Channel RCA Inputs
* 2 Channel Speaker Level Input
* Hi-Volt (200mV ~ 6.5v) Input Level Control
* Built-in Crossover (40~240Hz, LPF)
* 2 ~ 8 Ohm Load Impedance Capability
* Total Harmonic Distortion 0.03%
* Signal-to-Noise Ratio 100dB
* Dimensions: 8-7/8" x 2-1/4" x 7-7/8"
http://www.onlinecarstereo.com/CarAu...roductID=19066
I doubt you will notice a change in going w1v2 into re sr
at any case the Op already has the pioneer amp.
SO getting two subs that handle 150-200 RMS ea would be perfect.
If I were you I'd get 2 12" w1v2s in a nice ported box.
sorry for the posting of amp
have you thought about 1 ten?
you put 600 to 800 watts to 1 ten that will out do those 2 jl"s
i dont know if you have heard those subs yet, but you can find better .
look into these
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=295-460
or
http://www.parts-express.com/pe/pshowdetl.cfm?Partnumber=295-414
or
http://www.soundsolutionsaudio.com/zencart/index.php?main_page=product_info&cPath=2_18&products_id=54
or
http://www.soundsolutionsaudio.com/zencart/index.php?main_page=product_info&products_id=18
in the right box any of these subs will sound great.
If I were to go with just one sub would a 12 or 15 be better or will my 800 watt not be enough to push that.
I guess another way to put it is I have about a 400-500 dollar limit to get subs and a amp. Right now in my car I have 800 watt rockford fosgate wiring.
So if you want to go off that im looking for all suggestions on what to get.
my old setup was two e class alpine 10 inch sub with an older model 800 watt pioneer amp. one of my speakers blew and my amp just went out so im looking to get something different.
Going for SQ or SPL? Mix of both? How much of your trunk space do you want to keep?
A good combo I could think up off the top of my head would be an AQ1200.1 and an HDC3 15. $500 shipped exactly.
Goin for more bass. And im willing to use all the trunk space thats what its there for subs //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif haha.
will the 800 watt fosgate wiring run the aq1200?
icwe2
icwe2
LA
okiedokie
