Lock doors amp goes into protect mode
ZDudas
I was giving a demo the other day and the guy in the passenger seat bumped my door lock switch and when he did my subs cut off. I looked at my amp and the RED L.E.D protect light was on. I backed the volume all the way down and it came back with power and played fine. I just don't understand why is does this?
Voltage dropping from doing so I bet.
Do you have a multimeter? You could check it out.
But what amplifier, charging system upgrades if any, et cetera is your system comprised of?
Stock battery up front. All stock electrical. Sub amp is a rockford fosgate prime r1000.1d monoblock powering 2 sundown sd-2 12's. I have a eBay volt meter wired directly to the sub amp and the lowest I've seen it drop to is about 12.5. When I start the truck the volt meter reads 13.6, but when I play full tilt it drops to 12.5.................
it is repeatable? that's frickin' weird. those two systems should be independent... unless you have a modern GM and the CAN bus is somehow tied to the remote turn-on wire...
what vehicle and what head unit/remote turn-on source?
how is power wired (direct to battery?)
Those are super nice!! I may have to go that route if by chance they don't fit.
19
  • Locked
219
Amp
261
ZDudas
ZDudas
Tupelo, MS
keep_hope_alive
    May 12, 2024
Brendon Jenness
    May 11, 2024
