little help please!
  • 2
Wonderbread
Against Avatar Theft
16,940
Vancouver BC
hey guys, i ahve no installation experience, but i just need to test an amp out...
The amp is an older RF Punch 200a1. I have right now another 2 channle amp (Zapco Z50C2) pushing both fronts and rears, and would like to see if the RF will push them harder (it should it has a lot mroe power)
so teh question is, can i jstu swap the wires to the exact smae spots on the Rf amp and it should work right?
any blow-by-blow intstructions would be great, thanks all.
If the amps power inputs and speaker out are marked then it is a straight swap.. First Pull the primary fuse..should located close to the battery.. then swap out the wires..Insert fuse and go.
Mike
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
12
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
335
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
280
Wonderbread
Wonderbread
Vancouver BC
mykeys
winkychevelle
    May 24, 2024
