little help please!
  • 2
Wonderbread
Against Avatar Theft
16,940
Vancouver BC
hey guys, i ahve no installation experience, but i just need to test an amp out...
The amp is an older RF Punch 200a1. I have right now another 2 channle amp (Zapco Z50C2) pushing both fronts and rears, and would like to see if the RF will push them harder (it should it has a lot mroe power)
so teh question is, can i jstu swap the wires to the exact smae spots on the Rf amp and it should work right?
any blow-by-blow intstructions would be great, thanks all.
If the amps power inputs and speaker out are marked then it is a straight swap.. First Pull the primary fuse..should located close to the battery.. then swap out the wires..Insert fuse and go.
Mike
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
526
Wonderbread
Wonderbread
Vancouver BC
mykeys
