Little advice please?
loknload
I have a 2010 Toyota Tundra double cab and am trying to figure out my next sub setup. My enclosure can be a maximum of 5" deep and I can get up to .84 cF per sub. I ran Elemental Designs 11Kv.2's in my Tacoma and loved them but they have a 5" mounting depth so I can't use them in this setup. I have narrowed my sub search down to the MB Quart RLP304 or the Polk Audio MM1040. I listen to mostly rock with ocaisional pop and country. I'll have a Soundstream RUB1.1000D running them which gives me 800 watts at 2 ohms or 1000 at 1 ohm. I have never heard either of these subs and know that a pair of 12's like the RLP304's should go lower and move more air but it's a shallow mount so I don't know how that will affect performance. Any suggestions?
I have a 2010 Toyota Tundra double cab and am trying to figure out my next sub setup. My enclosure can be a maximum of 5" deep and I can get up to .84 cF per sub. I ran Elemental Designs 11Kv.2's in my Tacoma and loved them but they have a 5" mounting depth so I can't use them in this setup. I have narrowed my sub search down to the MBEKI Quart RLP304 or the Polk Audio MM1040. I listen to mostly rock with ocaisional pop and country. I'll have a Soundstream RUB1.1000D running them which gives me 800 watts at 2 ohms or 1000 at 1 ohm. I have never heard either of these subs and know that a pair of 12's like the RLP304's should go lower and move more air but it's a shallow mount so I don't know how that will affect performance. Any suggestions?
WoofersEtc.com - SD-2 10D4 - Sundown Audio 10" Dual 4-Ohm Subwoofer
I've been looking at subs and listening to what I could until I'm so worn out that it's still foggy. What I do know is that I did not like the MB Quart RLP304 at all and was fairly unimpressed with the Polk MM1040, although, the MM1040 wasn't bad, it was just lacking a little.
So, If I put two of the SD-2 10's in this enclosure TUNDRA DOUBLE CAB 2-10" VENTED 07-UP how do you guys think that will work? I assume it will have great output and get pretty low but I also want a decent amount of SQ that can keep up with rock music.
loknload
loknload
Woodburn, OR
loknload
