two SA-8 's dual 4 or dual 2 ?
luis_88
wanting your guys opinon on weither i should get dual 4 subs or dual 2 ? i know the lower you go the more loud it will get but SQ goes down and will get hotter. I wanna have these subs for a while so i'm not sure if they can handle 1ohm for a long period. will be for a daily application.
thanks guys ! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ok, forget everything u just said.
Now....Match the impedance of the subs to the amps output at the impedance u plan to run. Example: your amp does 1000w at one ohm, you buy two dual 4 subs and wire to one ohm to get the full 1000w, or if your amp does 1000w at 2 ohms, u get dual 2 ohm subs and wire to 2 ohms for full power
ive ran 1K on stock electrical. just dropped an Optima Yellow Top in, had no problems at all. i think i saw the lights dim once and that was on a cold morning at a local VW show and i had just started the car.
if ur runnning 2 SA-8s 1K is a good point to start at IMO. you can do just fine with less, but 1K sounds really nice. :)
Matt
edit it was 1K @1ohm if it matters.
i'll probably go with 1ohm then if its not a issue as it will be cheaper with amps , i'm thinking of running about 600 clean rms each. I heard jacob from sundown has his 8v2 with about 800 rms daily, some one can comment on this .
Nice quote fegg
Lulz, might as well embrace it dude. You're now the XFL guy //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
---------- Post added at 12:11 AM ---------- Previous post was at 12:11 AM ----------
Ok so how many subs are you running? and yes if you burn amps up at 1 ohm you sick at life
He's only running two
luis_88
luis_88
Wichita, ks
luis_88
