liquid deadening on door panels
I dont think it's a bad idea. It's just hard cause you have to put a lot of thin layers on where on a flat surface, like the floor or trunk floor you can glob it on. that's why people say not a good idea.
Oh by panels do you mean the plastic part or the door frame? I dont think the liquid will stick to well to the plastic unless you scuff it with sandpaper and even then you take a chance.
Think I should use the rest of my liquid on my door panels? I read somewhere that its not a good idea, but dont see why it wouldnt be, so thought Id get some suggestions......
you probably already know this... but thats what i did.
5 days after the first coat was put on and i've had no problems, nothings falling off or flaking off or anything.
so i guess i'm alright ?
i'll tell you if i have problems down the road but it seems to stick well enough to plastic surfaces....
make sure to sand the surface first tho, whether it be metal or plastic...
zachzchw
zachzchw
ohio
Insomniac119
vegang
vegang
