Line Out Converter
Ok heres my Understanding
Find theese Wires
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Run Four Wires from my Bought AMp And Splice them in with them Wires ABove
Then Run All Them Wires That i Jus Spliced Togethher Into The LOc?
And then lol run RCA's Only The Rear Ones from the Loc Into to the amp
Your amp has two RCA inputs, a left channel and a right channel.
You want to splice into both rear speakers + - wires. Connect those wires to the Rear Right and Rear left inputs on the LOC.
Then connect an RCA cable to your amp and send the bridged speaker outs to your subs.
Slice Back the COvers On these wires
Run a wire from those wires to the Rear Right and Rear left inputs on the LOC
then put the Rca's in the left channel and a right channel
wait a minute i am looking amy LOC..and the only thing that says Left Rear And Right Rear is a rca input so how am i goin to run a wire to them?
No problem dude, it was my pleasure. And yea, Ive been here for like half a year.
Ive spent a crap load of time working on my taurus's audio system, so I pretty much know how the whole thing works.
Anyways, I want to basically sum everything up everything weve talked about. So hopefully this will make sense to you now.
See, heres the thing. My ORIGNAL explanation was for using the amp you bought to power your interior car speakers. Since this isnt the case, your gonna leave your factory speaker wires alone.
I originally stated that you would have to cut the factory amp wires. Send the amp out wires into the LOC. Connect the LOC to you pioneer via RCA cable. And then send the speaker level outs back into your factory speaker wires.
Here is whats different. Since your pioneer amp is only for powering your subs. You arent going to have to cut the wires apart like it is in the pic I originally posted. That is only if your are using an aftermarket amp to power your interior speakers.
What you want to do is use the amp to power your sub. So instead of cutting into the wiring like in the pic I originally gave you. All you need to do is cut away some of the sheething so you can take the signal from your factory amp and send it directly to your pioneer via the LOC. Then all you need to do is connect the speaker level outs on your pioneer and connect it to your subs.
craigmb
craigmb
kentucky
cotjones
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
