Line Out Converter
Ohh, and another thing. Is this only going to be powering the front speakers?
Since you wont need all 4 rca's from the LOC like I did, you should only need to the cut and splice half the wire in the pic.
You're then going to run your own wire from these speaker outputs and splice them into the factory wiring pointed on by the yellow arrow
Ok so i splice 4 of the wires coming from my speaker outputs into theese 8 wires
Left Rear Speaker Positive Wire (+): Gray/Blue
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Black/Violet
Right Rear Speaker Negative Wire (-): Orange/Violet
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Tan/Green
Right Front Speaker Negative Wire (-): Green/Orange
and then connect them into the top of the LOC?
I wouldnt do that. (yea, my comp freaked out too, I had to restart)
What are you using this amp for? Im assuming for you car speakers and not a subwoofer right?
So i connect 4 seperate wires into the Speaker outputs...RUn them and splice the 4 wires from the speaker outputs into theese 8 wires?
and then run them 8 wires to the top of the LOC
Your gonna take these wires and splice them into your LOC. (since you amp only has two RCA jacks, you dont need to connect the rears)
Then run an RCA from the LOC to your amp. Then run your own wire to these wires again
craigmb
craigmb
kentucky
cotjones
