Lights in Chevy Silveardo Dimming!
lilicep06
hey guys, I just installed a Alpine Type R 12' Subwoofer with a Kenwood 500 Watt Mono Block amp in my 06 Chevy Silverado! And Its still breaking in but my lights are dimming and I have a Rockford Fost Gate Capciator on it aswell 8 guage wires and 12 guage speaker wire does anyone know what i could do to stop the lights dimming?
Thanks Phil
Thanks Phil
the wire on ur cap should at least be 4 gauge.....what you should do is do the big three in 4 gauge or 1/0....that will help a lot.....and then i would look into a kinetik, optima, powermaster etc......to run under the hood.....the amp does not seem that efficient....is your power wire 8 gauge?
i believe it is an 8 guage wire one the cap! And its a new Ac Delco battery! This is crazy and right now im only running 300 watts RMS due to the sub being new and Im trynin to break it in! Would a new battery work or would just getting four guage wire? Which would probably be best?
Thanks Phil
bigger alt... chevy alts kinda blow, my cuz has a pretty small memphis amp and his dimmed almost all the way out
Go over all connections, not just the amp, and make sure they are tight.. Where does he say he has done the big 3 ? I didn't see that.... Maybe the cap is hurting ya ?
I have had at least 6 different chevys and i have not had that problem, even with more wattage..
lilicep06
lilicep06
Crisfield MD
Ignatowski
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
