HAHA yea your right because at 120hz+ you use a 3:2 pulldown. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh:duh.. I think this is like the 3rd thread this week hes tried to be a master of something but really knws nothing.. the fact he thought a 3:2 pulldown test has nothing to do with the way an image looks is enough alone..
your a fawking idiot.. plasma are 600hz ( technically ) dumb shit2 words: (60... Hz) //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I guess morons will be morons.
Plasmas 600hz has nothing to do with screen refresh rate.your a fawking idiot.. plasma are 600hz ( technically ) dumb shit
And LCD's screen refresh rate has nothing to do with motion blur... that is caused by slow pixel response time when swapping RGB colors. Plasma phosphors do not have that problem, which is why there is no motion blur, and no need to interpolate extra frames which are not part of the original material (whether duplicate or black frames) to try to hide it.Plasmas 600hz has nothing to do with screen refresh rate.
Which is exactly why I no longer support LCD, they are trying hard every year to improve, but they have yet to catch plasma in overall performance. Sad actually, because LCD's still sell more..And LCD's screen refresh rate has nothing to do with motion blur... that is caused by slow pixel response time when swapping RGB colors. Plasma phosphors do not have that problem, which is why there is no motion blur, and no need to interpolate extra frames which are not part of the original material (whether duplicate or black frames) to try to hide it.
Bottom line... LCDs/LED-backlit LCDs have motion blur, plasmas don't.
AHHHH you FINALLY said it! thank you.your a fawking idiot.. plasma are 600hz ( technically ) dumb shit
A 60Hz signal flashed in 10 subfields.... sort of like a 60Hz input signal flashed 2-4x on your LCD to come up with 120Hz or 240Hz respectively????AHHHH you FINALLY said it! thank you.
A plamsa uses Sub-Field Motion, A 60 hz signal flashed in 10 subfields to take advantage of that quick pixel time.
However, Try hooking up your 3D source to that "600hz" TV and see what you get.
With upcoming technology if you by less than a true 120hz TV you will be missing out.
And the only differences with the current 120~240hz model LCD's and >2ms pixel response and plasmas are indiscernible by the human eye.
Bassically plasma uses a neat science trick to fool you into thinking its fast when its at it's limits, while LCD's speed capability is indefinite.
And no, 3:2 pulldown is not necessary/used on 120/240 hz TV's
yea.. already cleared that up with ( technically ) and wow, you can copy and paste shit you found on the net //content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif:clap:AHHHH you FINALLY said it! thank you.
not to mention your gonna have one hell of a headache after trying to view a movie with HDMI 1.3sA 60Hz signal flashed in 10 subfields.... sort of like a 60Hz input signal flashed 2-4x on your LCD to come up with 120Hz or 240Hz respectively????
I guess you can explain, then, why a 3D plasma television took top honors at last week's CES? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif Why not try hooking up that 3D source to your current 240Hz LCD? Think it's going to work properly? NO! Because they're not designed for 3D, moron.
And yes, a 2ms delay in pixel change can most certainly be noticed by the human eye when it is spread across hundreds to thousands of pixels as an object moves across a screen and each pixel lags behind its neighbors.
You are honestly going to sit here and tell me that there is no motion blur with LCDs???? Not noticeable at all? Go ahead... say it.
