Lanzar Vibe 1200.1d/ Is it a good amp?
  • Thread starter Unregistered
  • Start date
  • Replies 2
  • Views 2K
  • 2
U
Unregistered
Guest
I am shopping for amps, im not for sur ewhat i want. I want to stay below $300. I saw lanzar vibe 1200.1d for $260 it looked like it woudl be good, can anyone tell me about them. Or any other amps taht kick ass under $300.
ive found the jbl 1200.1 on yahoo stores for 300 its a sweet amp its usually around 320 at most other sites though spend the little extra and ge it you will be happy with it
Lanzar's had some known problems with those amps. I ordered a 1200D back in september, on the 2nd day of use it started blowing my main power fuse. I couldn't figure out the problem so I returned it for exchange. The replacement amp did the same thing. And when I tried to replace the in-line fuse the amp burned up. This time it was sent back to lanzar for service. The third amp has been going strong for a couple weeks now. I still don't know whether they repaired my blown one or just sent me a new one.
My general opinion is that if you happen to get a good one, they're great amps, but if you get a lemon it might be a headache to get a hold of one that's any good. Plus, Lanzar's customer support doesn't appear to be all that great. BTW, I just sold my 1200D on ebay, I'm replacing it with an optidrive 1000.1D.
Not a family member here....but I sure as hell felt like one as I devoured this thread. The ONLY REASON I vandalize this tapestry of broken hearts...
22
4K
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
107
I have not really heard anything bad about Vibe Audio. If you are buying it new, then no reason to not try it out. It may have a 3 month...
I would put the full range to ch.3&4, and low pass on ch.5&6. The 6.1200 line out should be full range unless it has a dedicated x-over. In that...
Guest
n2audio
    May 16, 2024
    May 16, 2024
