BassAddictJ
So i've been running my kx 2500.1 @ 2ohm nominal for the last year. i recently reconed the btl to 1 ohm. Now the bass will cut out at and only at full tilt. All connections for power/grounds, speaker wires, and signal wires are solid. Voltage drops typically to 13v, no lower than 12.5v. Input signal voltage is actually slightly lower since the bass eq level is slightly lower to reach full tilt.
ive used kx 2500.1's at 1 ohm nominal in the past with the same kind of electrical and never had this issue. lame
