Knukonceptz size
Black Truck 10
I just ordered a bunch of their 1/0 cable and I am about to purchase some distro blocks and fuse holders. I am not reading this right and I am seeing their cable as 66MM which is like 2 inches so I know thats not right. Does anybody know if this cable http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL will fit into this distro block http://cgi.ebay.com/AUDIOPIPE-DISTRIBUTION-BLK-1-X-0-4-G-IN-4-X-4-G-OUT_W0QQitemZ320282687055QQcmdZViewItem?hash=item320282687055&_trkparms=72%3A1073%7C39%3A1%7C66%3A2%7C65%3A12&_trksid=p3286.c0.m14.l1318 This is the same1 Team H&K is selling. I did a search, and couldnt find anything about their size other then some1 posted it is closer to 2/0.
thats 66 square millimeters. Area.
The KLMX isn't going to fit into any standard 1/0 fitting without trimming. Look at getting some Kicker blocks since they are oversized 1/0 to fit their Hyperflex wire.
By trimming the wires, would I loose any conductivity or anything with that?
conductivity is a function of area AND length. At a length of 1" or less you'd have to trim a WHOLE lot of strands to have any meaningful effect on the current capability of the connection.
yes......... the rest of the wire will still have the full amount of strands. even though the wire is cut on the end, the current will flow to the full amount of strands within about an inch. meaning that sense the wire will only have less strands for about an inch you wont notice it. its not enough resistance to cause voltage drops or to melt the plastic coating on the wire. ( unless your in comps and need every little bit of power ) and it still would not make that much of a diffrence. if it were a couple feet then you might have problems.
Black Truck 10
Black Truck 10
Houston, Tx
kicker33
