KnuKonceptz RCA's
Okay, that is good to know. How are the SoundDrive RCAs shielding different? What makes them superior?
We use a braided or twisted copper shield depending on the series. It is thicker and blocks lower frequency interference. The stranded shields like this are effective against EMI, but not so effective against RFI because the very high frequency wavelengths are smaller than the gaps between strands of the wire.
Quick reference sheet:
type of interference // frequencies it affects // how to best block it
EMI // audio frequencies // twisted or braided copper shields
RFI // video frequencies // foil shield
IT THE PEAK OF HZ THAT YOUR BOX PLAYS...FOR EXAMPLE!!! So if i tuned to 35hz on winisd it shows my peak would be 3.4 db at 37 hz, and 0 db at 32 hz
Yep you are off bud. Winisd only shows what it will do in a open air environment at 1w. It does not take into account the vehicles RF and cabin gain. 0db at 32hz means it wouldn't be doing anything.
WINISD BETA MAY BUT WinISD alpha you can see the effect of box size on power handling and responce line and you can easily change parameters around to get lower bass extension, but will often run into increasing the size of the dip in the responce after your fb. which is your 0db's @ different hz to your tuning!!!!WinISD alpha you can add filters to the response to simulate crossover interaction with the driver. Then look at the excursion profile, increase the signal until you get to xmax. Flip over to SPL and you now know what you can do.
No just stop.
Nothing like coping and pasting a bunch of random *** **** to this tread to make me look like a genius.LOL been fun playing with you noloud4u for you...I've never even used winisd beta or alpha hell i don't even know if they even exist...LOL god i'm good!!!!
It didn't make you look like a genius.
Here is another random thread that I've copied and pasted for your amusement.... Re: Meca rules question
It's not so much shops as it is manufactors.
The real genius here is you noloud4u with the manufactors....Think you meant manufacturers..... look made me look like a genius again!!!
61ragtop
61ragtop
Langley, BC
Dmac1991
