Kappa Perfect 12s, minimum airspace?
Mugen
Superhero.
Yea, I order two Infinity Kappa Perfect 12s (crutchfield had buy one get one free) and I can eithe cram two in my truck with around .8 cubic ft airspace a piece, or just use one with over 1cu ft of airspace. The spec sheet says to use 1 cu ft, so I was just wondering if I'd be better off having 2 12"s with less than adequate airspace or 1 12" that would have plenty? Also, giving it a little more than 1 cu ft (say 1.3?) would probably allow for a little deeper notes, right?
What would you guys do?
EDIT:
And this box will be custom built, so I can build it as I please, and all my calculations (double checked) are showing .85cu ft per sub. That's including taking off an inch and a half because of the 3/4" thick MDF on all sides, so it's pretty accurate I think. The actual dimensions I can work with is 19.5" tall x 31" long 5" depth at top and 9" depth at bottom.
its the stuffing from a pillow //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. very cheap but really helps and in my case the subs sound even tighter and more deep sounding
why cant you go more than 31 inches wide?
Just move your jack stuff and go the full width of the cab. should give you enough room to give adequate airspace for both subs
Look at the date of the first post //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
And yes, that is with my jack and stuff out, the problem is that my rear mids like, stick out. Doesn't matter though, I'm gonna be getting a new car soon (December hopefully) with either 2 AA Assassin 12"s or 1 15" Fi Q //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Maybe, but I'm happy with these AA Assassin 8"s for now. Besides, I wasn't really accounting for the subs to have breathing room in front of my seats, that size would've had them like pushing on the seat when they excurted (is that even a word?). Meh, what's done is done //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Mugen
Superhero.
Mugen
Walker, LA
Mugen
