just wondering
NewToTheGrounds
would 2 of the same ported boxes with each the same sub and amp powering them be the same as a single enclosure tuned to the same hz and equivelent volume for 2 subs together preform the same or would one set up be better than the other , basically 2 seperate boxes be the same as one box with both subs.
wouldn't matter either way. it would be safer separate if you were doing a sealed enclosure. remember, if you put them together, you'll need to double the port area but not necessarly it's length. you will have to recalculate to get the correct length.
NewToTheGrounds
NewToTheGrounds
Canada,ON
Trixter
