2 12" L7's Space?
Jared530
Drop bombs
Ok i searched around and it seems that the l7's prefer alot of airspace in order to be ported. Im building my friends box, with 2 12"s in them. Its going to be going into a Carola with max demensions of 33x13x16.
Do you think that the box should be ported or sealed?
Would the ported box get loud, But just sound crappy?
With that amount of space,IMO, I would do 1 L7 ported or a couple of beefy 10's. //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
they will not sound all that great in that amount of volume... Actually 1 of the drivers in the correct box with perform much better then 2 "choked" drivers.
I have done many of tests with these drivers and 3.25 cu/ft @ 34Hz per driver is the sweat spot I have found.
Also, if you want anywhere near the correct amount of port volume for a 1 sub ported enclosure the best your going to do is 2.35 cu/ft @ 34Hz.
it would still sound decent in that amount, just not up to its potential. correct?
i have no experience with L7's.
Correct. As for 1 driver.
If your planing on 2 you will most likely have less output then with 1, those drivers will be be massivly "choked".
I guess he can do external ports if he really wants to...that might be better...
I would do just one though...tell him to sell the other one and make some money back...
Jared530
Drop bombs
Jared530
Sacramento, Ca
itzme218
