Just Need to Check
gabe8501
20
TX
I want to make sure I wired my subs the correct way. I have two Diamond D6 12s, DVC 4OHM. I want to run them at 1 ohm.
Here we go, I ran the speaker wire out of my amp and then spliced it from one + and one - to two +'s and two -'s. Then I rean one set of +&- to one sub and the other set to the other sub. And finally wired the +'s on the subs together and the -'s on the subs togehter. Is that yielding a 1 ohm load??
I know, I know..... crutchfield and sounddomain have guides. I just wanted to make sure my dumb *** didn't screw anything up when I spliced the speaker wire.
Any info would be greatly appreciated. Thanks
does it look like this?
Sure does. Except it's not really one run of speaker wire from the amp.... I kinda used existing speaker wire on the subs and then just crimped the fuggers with the speaker wire coming from the amp.
gabe8501
gabe8501
TX
skadude016
Mike Mccabe
