Just installed. What is wrong with my sound?
Make sure BOTH AMPS are grounded to the same spot. if they arent, it could be causing a ground loop.
edit, didnt read the earlier post, but reground them anyways. its most likely the prob.
gl
i wired the speakers right from the amp with other wires. 12 gauge wire actually.
Tommorow im going to try to wire my RCA's on the opposite side of the power cable.
For the grounding, i grounded the amps and caps underneathe my back seat. Its the same spot that the professional place grounded it when they installed for 4 channel amp but i used that for my subs. Now i installed a new amp and ran the 4 channel to my speakers.
Should the cap not be ground at the same spot as the two amps?
npcout
npcout
PA
npcout
michigan born
    May 14, 2026
michigan born
    May 14, 2026
