a "mono-block" means it has 1 channel. Nothing to do with what impedance it can handle. please just stop spreading misinformation. I have no idea why you're bringing in amplifier topography either....
Anyways, if you have a dmm. turn it to AC and put the positive probe on the + speaker terminal and the negative probe at the negative speaker terminal (both at the amp and the box) and raise and lower the volume. THere should be an increase and decrease in volts AC. If there is not, then either the amp is not getting signal, or your amplifier is not outputting.
To test if it's getting signal take the meter (same settings) and put the positive probe on the center pole of the rca and the negative on the outer shield (all done at the tip). Once again this should raise and lower with volume (depending on your HU anywhere from .5v AC to 2 or 4 or 5v AC). Becareful not to touch any of the probes together while testing these.
Also Alpines blue square in the middle usually turns red when in protect.
Check the voltage at the amplifier too. Sometimes amps will turn on but they will not actually be getting enough voltage and current (if the battery terminals corroded, etc.) and thus it will appear as if the amplifier is on and operating, when its not.
P.S. the amps not 1 ohm stable, especially with enough power to adequately push the P3's. LMK if you need a P1000-1BD //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
