I will try to translate from engineer to English. The room will effect the response greatly. Using more than one subwoofer at different places in the room can/will help. And different type/size/tuning can sound better in your room.
Thank you.
ME, please understand I am not trying to diminish what you are saying, Yes you will have gains and nulls at different frequencies and different locations. and I am sure you can try to eliminate some of these in the design. But if the OP cares about having the flattest fr then a powerful eq and a way to measure the rooms response will be needed in the end. I see no need to limit the response and have worse group delay and phase by using a bp type enclosure. I would say that a sealed box could be better in this regard depending on the room. However using a DSP can help more than the design, including the room modeling, can. Also how can you model the room accurately? Everything in the room changes the response, It is easier to play with location of the subs and eq to get the response you like, than to try to model it. Plus, and please no one take this the wrong way, I don't think the OP, or people in general, care if they have a flat response. As long as it is not WAY off, it is fine. If I am wrong than everyone would use a HT design service to come to there house and setup/tune everything. (i.e. look at how many people LOVE Bose!)
Don;t worry, you cannot diminish anything I say.....it's not probable. Anyways, here are a few things to note about what you say.........
1. It's is not about having a flat response curve. It is about creating the curve you DO WANT.
2. The EQ being a necessity is not something you have control over when dealing with larger rooms. If you care enough about it, yes....it is recommended, BUT you cannot leave out the design being able to help. Remember the saying, "two heads are better than one"? Well, in this case, two ways to control response is better than one. No difference.
3. A sealed box is not an ideal design the larger the room. You will have enough losses based on distance and time, that will effect the said phase and GD by limiting the designs efficiency and abilities. It is not the recommended design in a larger room, but more so in a smaller room-and since you feel the need to "simplify" my meanings, I will not get into it right now.
4. If you do not know how to model a room accurately, then you have to reason to try to simplify what I discuss. As you, I am not diminishing you either, but if you have to ask the question, then you do not know the answer yourself. It can be done......trust me. Otherwise, designing would be pointless, right?
5. Making things easier to do, does not mean it is more accurate. In fact, its normally quite the opposite. I understand that the common consumer wants to walk right in to the nearest sh itty best buy and here whatever they want to hear to make them comfortable with a purchase. But this is not the way I do things, I hope you understand. For those that want to be simple, then just do not listen to my guidance. You will be exactly where you want to be, no worries. Everybody's happy. For those who want more accurate products based on everything they should be, then that is why I am here.
6. Yes, location of the sub is a nice controlling factor in the room response. That was mentioned.
7. BOSE............wow. Did you know that their world changing engineering was not even their own creation? Plus, they are mostly famous for dipole propagation, not room response control(though this is never discussed). Everybody loves them because of marketing skills, and the ability to keep it simple for the customer and make them believe that what they make is better engineered than anything else....when in fact, quarter-wave design, and fancy electronics controlling is their way to do this. Not equalization, or room gain control, or anything to do with a room at all( I say that in a sense of response control). If that was true, they would offer a service to have a product designed from scratch. And if they do, that would be the only thing they are doing correct.
Their key to creating consumer based sound is to add low end output to all of their small designs. Yes, they are a great company, but not anything different than anyone else that engineers for the same purpose(key words..same purpose. that means only the few that do).
And last, the reason it works for most people, is that they either have not heard the difference of true stereo imaging, EVEN in bass reproduction(its possible), or they simply do not care about the specifics and accept the errors that come with the fancy designs, becasue the ear, as I mentioned before, is very forgiving. We can adjust to a sound or even a noise within a few minutes of listening. That is the key to marketing a product. Make it acceptable and it will be accepted. A great example of this is anechoic response curves. I use those in my store for my store products. Though they are not as accurate as full custom designs, many will not be able to tell the difference, BECAUSE of the ear factor of forgiveness. It is a matter of acceptance as long as, like you said, "it is not WAY off".
Im not arguing, I am controlling my abilities to give great advice and not let people try to step over it. Nothing personal at all....just business. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
