Jmac, a little port help please....
  • 2
ridered36
Dont bufu rabid squirrels
I was wondering if you can tell me the port length, width and height i will need for 32hz for a slot port. The boxes external dimensions are: Height-14", Width-23.5", and Depth-23.5". The sub is a 12" XXX. If you need anymore info let me know.
And when i build the slot port, it goes in the shape of a "L" correct, or is it just straight back.
Thanks for the help.
It does not have to be in the shape of an L....thats just if you run out of room....anyways you can make the port an infinite number of size in width and height, ...i did a general one for you with a 12"*2" slot, its going to run you about 13.53" in length (those are all inside demensions. I got your box volume to be 3.5 less 0.1 for the driver (thats a guess, what exactly is the driver displament?) unless that is way off for driver displacment(which i doubt) thats going to tune you right around 32 hz.
i assumed you have me outside demensions, but those are inside? if thats the case (12*23.5*23.5)/1728 is 4.47 cubic feet...... less the 0.1, I will use 4.37 for the port calculation. we can keep the 12*2 opening and the length changes to......9.41 inches
Originally posted by evo2k3 i assumed you have me outside demensions, but those are inside? if thats the case (12*23.5*23.5)/1728 is 4.47 cubic feet...... less the 0.1, I will use 4.37 for the port calculation. we can keep the 12*2 opening and the length changes to......9.41 inches
OK lets go, 14*23.5*23.5-external dimensions, minus .2 for the driver. That should give me roughly 4 cubic feet after all is said and done.
i doubt that a xxx is 0.2 cubic feet -- my 12w7 is only 0.09 -- dont think it is that much smaller. anyways you shouldn't be guessing, look it up in your manual or online and tell me what it exactly is --if those are external demensions and you used 3/4" mdf, you only have 3.5 cubes inside, less the 0.1 for the driver, leaving 3.4 before the port--so the length becomes 13.53 inches.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
Well lets say I was running the tablet and 3 amps, would I use something more along the lines of a line output converter so that I would be able...
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
727
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
902
ridered36
ridered36
Knoxville, IL
evo2k3
    May 20, 2024
    May 20, 2024
