Jl audio jx 500/1d keeps going to protect mode
cesarortiz
You guys so I finally put my littl set up on my 1 series and for some reason my amp keeps going on protect mode
It keeps shutting off my woofer
what can it be
My w6 is too much for the amp ?
I have a w6 v3
And I have it at 2 ohms
And the amp says 200 is at 500 watts so what can it be?
what can it be
I have a w6 v3
It could be that your amp can't supply what the sub is asking for.
Sent from my MHA-L09 using Tapatalk
Check ground wire.Make sure it's bare metal to meatl
Gain setting too high. If so, correct it properly.
Make sure your actually giving the amp a 2 ohm final impedance ohm load and not something lower, Yes it does happen, accident occasions.
Check ground wire.Make sure it's bare metal to meatlGain setting too high. If so, correct it properly.
So I was told that my car isn't giving the amp enough voltage to keep the amp on
It keeps going to protect mode because I guess there isn't enough voltage going to the amp
They said the amp needs 14 volts
Is this true
They told me a capacitor will solve the problem
Not many use capacitors any more. Look at doing the big 3 upgrade and getting a better battery (optima or something similar). Your car must have a pretty small alternator. You could replace that but there are more likely cheaper fixes.
Right now I'm trying out a 1200 rocketfosgate amp and that one won't turn off
But they say that only jl are the brand that is real delicate about voltage
What if I get a new battery and it still turns off lol
Then what can it be
Also what I notice is that the amp gets way tooo hot
Is that normal
Is this true
14 volts to run an amp??? Wonder if they mean for the actual vehicle to be @ 14.4 for the amp to function properly. That amp's voltage runs anywhere from 2-10 voltage, depending upon your HU voltage range.
Sounds like your electrical isn't up to par. Also....do the big 3....it will help out A LOT.
Gawd no...phuck Optima. They aren't what they used to be years ago. Quality is **** now, and they are overpriced. Not to mention they now made in Mexico. They don't last as long either as compared to other batteries.
I'd look into batteries such as Interstate, XS, Duracell, Diehard, Juicebox,
So I'm reading the manual on the amp
And it says recommended fuse is 50a
I have a 60a can that be the problem ?
Or that doesn't mean anything
And it says recommended fuse is 50 amp
I have a 60 amp can that be the problem ?
That's just your inline fuse....since the amp doesn't have any on board. Meaning, on the side of the amp. Some amps come fused. I don't think 60 would hurt it use it for now then when the time comes, switch over to the recommended 50 because you don't wanna overdriver the amp just in case, or even blow it/ruin it. 50 is just it's maximum amperage draw.
Do you think that's maybe the reason why the amp is wayy tooooo hot.
or maybe that's the reason why it keeps going to protect mode
I'm just a bit confused
Right now I am running another amp and it doesn't turn off
I run the jl and it turns off
But then I ran the jl amp on another car and it worked great so I'm confused
Getting hot is clipping (over driving the amp) impedance to low or bad power/ground. A bad connection anywhere in the system will cause it. From the battery to the fuse to the input or ground.
Ok the signal is coming from a converter
The signal is coming from a stock subwoofer from my bmw 1 series
Is it that the signal is too strong that's one question
Now we tapped the back speaker just to see if it was the signal being too strong
But it was the exact same thing it keeps going to protected mode when it's played loud.
now the amp is rated to push 500 watts at 2 ohm
My speaker is at 2 ohm
500 watts should be perfect to push a w6
Is not like I want the speaker to give the most craziest bass
I just wanted something decent but
Man this problem is getting me upset lol
can it be the converter that's bad ?
Or maybe the guy got the wrong cables from the wooffer ?
Take that JL and have it bench tested at a trusted audio shop.Talk to the manager or ? and let them know whats going on..They may charge like $20 bucks, but most will charge nothing at all.That will be the first to rule out if its not the amp.
A Link would be very helpful. Id be interested in taking a look at some gear
206
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
334
cesarortiz
cesarortiz
Los Angeles
cesarortiz
