JBL to power 3 subs?
Mark_ab
The Alpha Male
I'm thinking of getting a 3rd Perfect 12 when I get my new car. A couple of questions here. Can the JBLBP1200.1 run 3 of them, or should I get another amp for the 3rd? And how would I have to wire them to get a 2 ohm load, if it's possible. Also, I was thinking of facing them inside, towards the cabin, and doing a stealth install. The car is a (probably) 91 Z34, which has a fairly sizable metal plate behind the rear seats. I'll probably port this, somehow. Any suggestions? Zane?
So long as you are running the SVC 4 ohm models- you should be able to do this.
You will be a a 1 ohm mono load, which the BP1200.1 will handle. You will likely need to add a fan to the amp to increase airflow, as this is usually necessary in any situation where the impedence is below 2 ohms.
Basically you will need to wire the subs together in paralel. Two 4 ohm subs in paralel yields a 2 ohm mono load, adding the 3rd will yield a 1 ohm mono load.
Just wire the 3rd sub in to your setup the same way the others are and you should be good to go!
take it easy,
-zane
Okay, thanks. That was the original plan, however, I wasn't sure if the JBL could handle a 1 ohm load. Will this be sufficient power for the subs? I'd imagine so, 400 a piece. What about the direction the subs are facing? Are there advantages to each, front or back?
If you look in the .pdf file for this amplifier on http://www.jbl.com it notes a 1 ohm load minimum. I have also verrified this and had no problems.
Concerning the direction your subs face- this is a matter of trial and error unfortunately. Each car has its own acoustical properties, some hinder and some improve sound. I can only say that the best thing to do is try the enclosure in several different positions and go with the one that sounds best. Most cars generally respond to bass better with the subs facing to the rear. This is mainly because they immediately have a surface to bounce sound off of and send it back into the car. This at times can cause some cancellation, so it is best to just find a location that you are happy with and then incorperate your install arround it.
take it easy,
-zane
Even though the 1200.1s say that you can only run them and a 2 ohm minimum. I have seen some running at 1.5 ohms fine but I have never personally tried one ohm.
Not trying to be an ass, but wouldn't (3) SVC 4 ohm subs make a 1.33 load? (4) SVC 4 ohm subs would be a 1 ohm load. Take the impedance and divide by the number of circuits (subs in this case) in parallel to determine the load.
Originally posted by Unregistered Basically you will need to wire the subs together in paralel. Two 4 ohm subs in paralel yields a 2 ohm mono load, adding the 3rd will yield a 1 ohm mono load.
This is correct in many circumstances, however, measure many a speaker rated at 4 ohms and it will read anywhere from 3.4 to 3.7 ohms on an ohm meter.
Just depends on the manufacturer, the material, and design of the speakers VC.
take it easy,
-zane
Originally posted by dr. no hey, the 1200.1 don't say they have a 2 ohm min. All the amps in that seriesare 1 ohm stable.
Both of mine says "slams into 2 ohms" on an orange sticker on the front. I should know, I have 2.
My bp600.1 also had the "slams into 2 ohms" sticker, but the owners manual says, "The total impedance of the speaker system connected to a BP Series amplifier must be at least 1 ohm".
Does anyone have an idea how much (the most) these comps can happily handle?
  • Locked
COMPLETED JBL power 3 ways
Those were really fantastic for the price. I wonder how many folks bought extras and kept them unused? Good luck.
Still available. Will offer free shipping to US lower 48 states.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
Mark_ab
The Alpha Male
Mark_ab
Edmonton, Alberta
RangerMan
    May 16, 2024
    May 16, 2024
