JBL, Memphis, or PG?
Daniel
Caraudio.com
863
SFLA
Alright, im trying to push 2 Blaupunkt PCwi1200's. I have three amps in mind.
1. JBL 600.1
2. PG XS2500
3. Memphis 16-ST300
Which one of these would do best with these subs? I want around 300W rms into each of the sub. I'd rather have SQ than SPL.
Its a good amp i know,but i dont want to push my subs that hard. I only want to put about 300W rms into each sub. The RMS for the sub is 200, but I will put into a sealed box with less than 1cuft. hoping to get around 250-275W RMS with the sub. Give or take a little, i want roughly around 300W rms from amp. The jbl 1200.1 will give more than that, wouldnt it?
600 is the max for my subs, and they might be overrated, i dont want to find out. so with the jbl 1200.1 can i put 300w rms into both at 4 ohms?
with the memphis 500d would it give 300W rms to each sub. i want one amp to power two 300w rms subs remember.
Just because an amp has more power than what you want to go to your subs doesn' t mean they will drive your subs harder than you want to.....just don't crank it up that loud..DUH !!//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Daniel
Caraudio.com
Daniel
SFLA
jellydime
    May 24, 2024
    May 23, 2024
