What causes an Amp to Clip?
  • 4
The first thing that a car audio amp does is boost the voltage in the amp to some value
+ - say 30volts. This is the rail voltage that supplies the output transistors. If the input voltage in the amp is high enough that the gain of the amp times input voltage goes higher then the rail voltage then the output signal becomes flat "clipped". because as the signal amplitude increases the output voltage can't go beyond the rail voltage. So the output becomes distorted and if driven hard enough the output could be almost square wave in shape this is when speakers tend to stop working because it is like hooking your speaker right up to a DC supply or battery. Therefore it melts or pushes the voice coil through the cone
In very simple terms, an amp clips when you over drive it. For example: trying to make a little amp act like a great big amp. Turn it up really loud it will clip.//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Make sure the fluttering sound you are hearing isn’t something flexing. When I start pushing my subs, the sunroof sliding cover flexes so much I...
29
5K
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
229
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
266
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
335
Rukuzz
Rukuzz
McAllen, Tx
Larrydehp920r
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
