Is this pioneer amp 2ohm stable?
Its 2-ohm stereo stable but you can't get it mono stable, but how would you be getting ohm loads like that from a 4 channel amp?
What Phoenix Gold amps are 2 ohm mono stable- Tantrum, Titanium, or GX?
What he asked was would it be good mid and high amp.. And yes it would be a very good mid and high amp. 2ohm stereo is definitely an option. If your speakers are 2 ohm speakers.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
  • Locked
GM-D9701. Used it to power a sound quality sub (Adire Brahma 15”). Was adult owned and carefully used (had a Mini DSP connected to it with a...
Many moons ago I was heavy into Car Audio Systems(Iasca stuff) but a ton of things have me removed and knowledge forgotten so I need a refresh. I...
adamawayfrommpa
adamawayfrommpa
North Carolina
jblloudclear
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
