Jacob's Wall Build Log
*laughs*
Depending on what I put in there... I may try to use Zs. I was thinking two 18s, though, so that may not be possible... unless I use Z v.2s... but those won't be ready for a few months.
*laughs*
:eek:... I thought the Zs were gone... v2 sounds good, just keep us updated, the more pics the better.
Also on a sidenote, received my amp yesterday. Excellent shipping.. i'll do a feedback thread shortly for ya.
Current version of the Z is on it's way out but it is being updated //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Glad you got the amp in good shape!
Have the one side and about 2/3 of the top sanded down smooth with a grinder after foam removal... got most of the foam off of the other side so I can grind it down soon too:
Top is 100% cleaned off... broke off a grinder disc on some of the concrete residue which shot off, hit my finger and leg (ouch), and then broke a fluorescent light *laughs* But... I got it done!
The last side is cleaned off... starting on the inside of the box:
Part of the floor had a bit of a hump from moisture -- side closest to camera -- had to grind that down so I can slide the baffle in.
TOP of the box is OFF... back wall slid back to where I want it.
I have around 38 cubes to work with in this position.
I can use the back wall... it is 6 layers of MDF with 2x4" lumber bracing, very sturdy.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
orangecounty1
