Worlddre
Big Darkie
what do you need the LOC if you are using the pxe?
heads up there is a giant gromet on the passenger side of the car behind the batt...if you take off all the plastic covering around the battery up to the windshield you will see it....however do not cut with a razor take a phillips screwdriver and poke a hole in it and work the power wire through it this will create a seal as you need one in this case as the grommet is facing downward and we dont want water on the passengers feet.....also with the pxe use both of the front inputs (which it doesnt tell you to in the manual) this will prevent a problem with output from the unit that i have run into a couple of times....and in case you didnt already know everything you need for the pxe install is under the rear deck on the drivers side. that is the factory amplifier location....take your input for the pxe from the factory amplifier input side not the output as the inputs are full range and the outputs are crossed over. that is all.....have fun
and a pic of the last g sedan i did just for fun and maybe an idear or two
