isbobaric 6th order designer
Jroo
Folks, who would you recommend as a good 6th order designer? I have had a couple of 4th orders before, but never tried a 6th order and my understanding is if the design isn’t right these things don’t perform well at all. I am looking at the MCM 8” subs and want to do 4 subs in an isobaric 6th order. I would be giving them about 700/800rms from an older Rockford 800a2. Again, who would you recommend for this?
BTW, here are the subs I’m looking at.
MCM Audio Select 8'' High Excursion Woofer - 120W RMS 4ohm | 55-2421 (552421) | MCM Audio Select
I'd imagine Buck could design one. But off topic: I ran one of those bad boys in an Autotuba design for over a year and it's a hell of a little sub.
A guy on another forum said the same thing about the autotuba. I had never heard of it and googled the design. How many watts did you run to your Autotuba? I get the impression that most people arent running more than 2 or 3 hundred watts based on the sub they pick.
What are your goals with this box and why the idea of running isobaric?
Couple of the reasons for the isobaric. With 4 I basically can end up with a 4ohm load which is way better for my amp(old school and doesnt really do 2 ohm with my electrical). I also had a isobaric sealed back in the day and loved it. I also am trying to cut as much space as possible and the MCM isnt really a high motor force sub so iso should work well.
I was running around 150W RMS to it, but I feel like it could handle more. My amp I had hooked to it would only output 150W RMS @ 4 Ohm. Honestly for what it is it gets down and gets pretty loud. I mean it's a $30 8" Sub.
Jroo
Jroo
richmond virginia
fatboytyler
