Is This Right????? 3 15" cvr's
  • 2
SatterBoi
Ok so i have built a few sealed boxes but never vented...So i did some numbers on the12volt.com and i want to make sure its right and will work before i build it........
Box....Width 48"--Height 20"--Depth 28"--Thickness 0.75 = 13.19249 cf
Vent....Width 48"--Height 4.5"--32 herts = 31" vent lenght.
So i am asking would this work for 3 15" Kicker cvr's? Subs up, Vents back
And if it is right i need to ask sorry if i sound dumb but the vent lenght is longer then the depth so do i make a L???
you need to subrtract port and sub volume, plus any other bracing you NEED to add to a 13 cube enclosure, and you should also probably 2x baffle it too being that big with 3 15s and yes, use an L bend, you measure the length of the port by the center of the port also..
I know im going to brace it but im not sure what i am going to use. Sorry but im not sure what you mean by subrtract port and volume and measure the lenght of port by the center? and for the L bend do i bend at 4.5" from the back of the box because the port is 4.5" wide?Thanks
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
5K
SatterBoi
SatterBoi
Portland, OR
SatterBoi
    May 31, 2024
    May 24, 2024
