Is this combo good?
Drew'sZ
Will these two different company's work well together alos can anyone give me some info on reliability? Will the subs be enough for the amp?
BX1605D - Hifonics 1 Ch. 1 x 1600-Watts Super D-Class Amplifier, and two RFD2210 - Rockford Fosgate 10" HX2 DVC 4Ohms 500W RMS Sub. The subs will go in a prefab sealed bow in my camaro don;t know the specs for the box. I would also apperciate any suggestions. Are these Audiobahn subs reliable AW1006T - Audiobahn 10" Dual 4 Ohms 900 Watt Flame Q Subwoofer
Usually you try to match an amp to the subs, and not the other way around. If you wire the subs to have an end load of 1 ohm, then the amp will work just fine. Just cause the sub states its rated at 1000 w, you dont necessarily need 1000w to make it sound good.
Drew'sZ
Drew'sZ
Fayetteville, NC
Drew'sZ
