Is this a good amp for this sub?
Are you talking about the big 3?
If you can't afford the ho alt just yet, a second agm near the amp will help. Biggest agm that will fit in the oem location, and big 3 in 0/1 gauge wire, same wire between the batteries as well dude. Much better to have more electrical than you need, you keep your signal cleanest that way, and you won't burn schit up that way either.
So it’s safe to use that powerful of an amp on that soundqubed
set gain right, don't use any bass boost., if u talking about hds3 it's rated 1200rms it'll take 1500-1600 easy with gain set right.. also with ported boxes u have a problem called box rise., which means sub don't really get all the power u have thats y most peeps here run 2-3x power subs are rated at..
yeah diff go d2 with that sq sub.. wolfram 1500.1 is still on sale i think. $229
Back to normal price $279... But the BigDWiz code still works for 10% off... So 252... Or the one I have for 229 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Dudebro241
Dudebro241
Pa
bigblank69
